I am using this PWM to control a simple 12VDC motor output (fuel pump on a vehicle). Can I simply connect the DCIN to the VREF or do I need to connect 12VDC to the DCIN? What is exactly the internal reference voltage of the K8004?
Thanks!
Thanks!
Perhaps you can also get some help on the Microchip forum forum.microchip.com/
Use figure C in the hook-up example in the manual of the K8004
Thanks, is the C configuration shown with a 1K resistor, or what?
yes
