I am sure they should be connected (you can measure this on the board), however, as I’ve said, BUK555 will probably work. It is up to you to give it a try…
I installed BUK555 and connected low power 5w halogen lamp. Everything works except I can’t adjust the output brightness. The voltage changes between GND and IN ports when I turn the 1K ohm POT but output voltage on LOAD ports does not change.
Tried to adjust RV1,2,3 no change. Is there some reference point I could check in this situation to find a faulty part etc. I connected everything like in diagram on PDF.
