I have a K8004 PWM controller and have a question about the output voltage. Im using an arduino microcontroller using its PWM pins for controlling the K8004, when I put 5 volts on the dc input im getting 14 volts on the load points (using a 14volt psu) but when regulating the dc input voltage to about 3volts Im getting only 1.3 volts at the load points… When the voltage gets up to 4.8 on the input im getting the full 14volts again
I cant get it to regulate my voltage using the dc input, what could be the problem? Is it broken?
regards, Tim.
