I have a problem with the K8004. Where I can connect the engine ? Should I keep the resistor on the LOAD bounds ?
Best regards
Rémy
UPUPUPUPUPUP
UP
The load resistor is just for testing.
Remove it and put the wires for the motor in its place.
Mind the polarity.
Thanks for your reply.
I have a new problem. I want to use this kit for for adjust the motor speed (powered by a 12V battery). What can I do ?
Please help me !
Nobody knows ?
Download the manual from here
http://www.vellemanusa.com/downloads/0/illustrated/illustrated_assembly_manual_k8004.pdf
Look at figure C on page 8.
Thanks for you reply. I have tried but the cuircuit board don’t work with the 12V battery.
What can I do ??
Best regards
Rémy
You could post Clear pictures (top and bottom) on a picture hosting website and put the link up here.
Maybe someone will find the error.
I have made a few of these and they have all worked.
Now a new problem : when I plug the battery, I get 12,57V on the electrical tester but when I plug the engine, the battery scream and nothing…
What is the problem ?
Photos in attachment
Best regards
Rémy.
I don’t see any control voltage either internal or external.
Please read and look at the pictures of pages 7 and 8 of the online manual
I use the first potentiometer on the circuit for regulate the voltage.
You don’t see another thing wrong ?
Best regards
That would be the problem.
RV1 sets the minimum voltage.
RV2 sets the maximum voltage
RV3 controls the frequency.
Please see page 9 of the manual.
Thanks! Had the same problem.
Glad to hear this helped.
Enjoy!
