K8000 v3 Comunication Problems
I’m using K8000 with:
Windows XP SP2 (using Parallel PCI extended card) and/or Windows Vista (motherboard LPT port).
The K8000 card is Master and no other card and printer are present on LPT port.
I’ve already installed: DLPORT IO driver.
I’m testing the interface with your soft Win_NT_2000_XP_test_soft.
I’ve done all pasive tests ‘recomended’ on the user manual (nothing is connected to LPT port):
With Mains N and L connected to 220Ac, no leds are ON.
The voltage on testpin +5V is present.
If I connect the test points from 1 to 16 one by one with earth test pin, the led from the respective channel is lighted up correctly.
As soon as I connect the interface to the printer port, and try test soft:
WinXP SP2 Computer: SCL led is always ON.
No one DigitalOutput can be setted to ON (I assume that a DO set to 1, should be represented with his led ON). Here is the problem added that the parallel addreses are not available because the Parallel port is at a PCI extension card.
Could it be posible to have your test software with the range ports of the extended PCI card?
WinVista Computer: Both leds: SDA and SCL are ON but very soft light. Here the LPT por is integrated on motherboard, but no one Output can be setted to ON
I only need to have available the DO; is there any kind of test that I can do to know where could be the issue?
You can use the DLL procedure SetI2CprinterPortAddress of the updated DLL.
You can download the updated K8D.DLL and K8E.EXE from:
box.net/shared/1txhmu1by6
Copy both files to Windows’ SYSTEM32 folder and to your application folder.
Usage (if the LPT port address is e.g. D080):
In Visual Basic VB6.0: SetI2CprinterPortAddress &hD080
In Delphi: SetI2CprinterPortAddress($D080);
In C: SetI2CprinterPortAddress(0xD080);
See also:
[forum.vellemanprojects.eu/t/k8000-parallel-port-address/923/1)
In Windows Vista you have to set the program’s compatibility mode.
More details how to do it:
windowshelp.microsoft.com/Window … 01033.mspx
Thanks for the help!
Sorry, I forgot to tell you that I already read that topic, and also downloaded the new files.
I’ve tried it again it in my WinVista PC (the XP SP2 will be available in a few days again). I’ve replaced again K8D.DLL and K8E.EXE from Windows system32 and also that ones from the ‘test soft’ folder.
Configuration tested:
LPT Port on MotherBoard.
Port is LPT1.
Adress: 378-37F.
Firstly I connect ‘Mains’ to 220Vac, then I conect the parallel cable. After Starting the PC, all leds are OFF.
After that, I start K8000 test software:
K8E.exe and K8000.exe in WinXP SP2 compatibility.
Leds SCL and SDA are blinking very lightly, but nothing else reacts at the interface board.
If I change the Adress at the K8000 software, then both leds stop blinking.
Is there other thing I could test or I should take in consideration?
Hi VEL255,
please, could you help me a little bit more?
I’m afraid to know if my board works correctly or not.
It seems that there is not LPT communication problem. There must be some other problem on the board.
Sorry that I can’t help in this case.
You may return the board to Velleman for checking.
Ok, that sounds the best solution for me.
How should I procedure to send the board for checking?
Please return it to:
Velleman Kit Tech Dept.
Legen Heirweg 33
9890 Gavere
Belgium
Ok, I’ve sent today the Interface.
Thanks for your help!
Recived and tested.
Thanks to Velleman, now is working perfect.
I think that I tried to change all IC’s and only left IC21. Obviously he was guilty.
Thanks to Velleman for the support and great work!
I want now to isolate my board. I saw somewhere a recomended housing for the k8000, but I can’t find it now.
Could you tell me which could be a recomended housing for the k8000.
Thanks!
Sorry, there is no dedicated enclosure for this board.
