I have K8000 but my portable PC Win xp does not have parallel ports. Is it possible to use a parallel adapter usb iee1284?
Thanks.
No, this is NOT possible.
Thanks for the answer
Hello
so, ok…it s clear…no usb adaptater. BUT THEN, what else?? what kind of other solution to use a k8000 with a modern laptop(which do not have a parallel port)?
a parallel-pcmcia? maybee?
Is your kit k8000 “hasbeen”?
thanks
K8000 is still available for specific puposes, but if you only have a USB port, you should consider K8055 or K8061…
Will it works with that?:
PCI EXPRESS to DB25
It seems that someone has got the K8000 running with a PCI parallel port card:
In this thread you’ll find some info how to find the LPT port address:
