In order to ensure the maximum DI acquisition speed, what card is it preferible to use among K8000, K8055 & K8061 ?
Can somebody give me a complete overview on that item ?
Looking forward for you soon
Thank you !!!
P&D
Thank you !!!
P&D
The K8061 is the highest speed:
Fast, clear and complete reply.
Thank you very much !!!
Regarding the 8055 response time, is this so slow because of the driver?
If the driver is on a polling cycle then I could increase the amount of cycles and by doing so improve the response time.
Or am I dumb and is it a hardware issue with some slow chip or something?
Regards,
Yves
The K8055 uses low speed USB interrupt protocol.
Regardless of the name “interrupt” it uses polling system. The polling interval is 10ms. This is based on the USB standard and hard-coded to the firmware.
