K8000 inVB6 "privileged instruction"
When I restarted my Pc yesterday I received the following error from the K8e.exe “privileged instruction”. I receive this error in previous goodworking programs in VB6.
Can somebody help me whith this problem
Thanks,
Carl
Make sure you have full administrator rights.
If this does not solve the problem, try below:
Enter regedit: Click Start, Run and type regedit and click OK.
In regedit look under:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\
There should be a “DLPortIO” key (folder) in there.
If there is, delete it, reboot and reinstall DLPortIO by running the Install_drv.exe.
problem solved
Many thanks
Carl
It works for me too!
Thanks!
