K8000 Communications Problems
Using your example VB6 Code, double clicking in the Source directory, The app starts in VB6 and works correctly.
running your sample code from the recent projects tab in VB6 does not work.
a message box stating that this is the I/O routine for the K8000 card. This is not a stand alone program.
Can you please explain why this is.
I have tried all the other suggestions that have been posted to no avail!
:cry:
Make sure you start the right .exe
Yes It appears that I had an old K8e.exe 231kb, replacing with the the 231kb version has solved the problem
:smiley:
