K8000 and K2633
I have a question concerning the combination of the K8000 interface board with a K2633 Relay Card.
What kind of resistors do I need to use for RX at the relay card?
Can I use the 820 ohms which are being supplied with the relay card or should I use a different type as I want to use it with the K8000?
If not what type of resistor to use, ohm and watt?
Thanks for your help!
The supplied resistors should do fine
Ok, thank u!
