I am using the new K8d.dll(2004) with the option to use the [color=#FF0000]SetI2CprinterPortAddress [/color]and not the [color=#0000FF]SelectI2CprinterPort[/color] function like in the old dll file. But I have noticed a problem in the new version;
When you connect a voltage on the analog input (AD1, AD2, AD3, AD4) and you use the old dll with the [color=#0000FF]SelectI2CprinterPort[/color] to readout the measurement on the pc it will work fine. But when you use the newer dll version with the [color=#FF0000]SetI2CprinterPortAddress [/color] it will not work. Al the digital IO´s works fine on both dll’s but only the AD1…AD4 don´t work on the new one. (I did not test the other ports: DAC1…DAC8 and DA1)
I believe this problem is in the dll it self and not in another place, but I could be wrong. Please let me know If any of you have a solution.
Thanks,
