K8000, 2 problems
hello,
I ve a k8000, and 2 big problems
First: with the test software…I can light on the leds, but no volt on the blue borns IO when 220v on the white borns
Second: unable to use the k8d.dll with vb2008express…and even if I put the file directly on the “bin” of my vb project (+ the fasttime32.dll + the k8e.exe + the dlportio.dll and .sys)…unable to access the k8000 routines to compile a program with vb2008express
Solutions??
The digital outputs of the card are open collector outputs, so there is no voltage coming out of them.
Sorry, no VB2008 experience. Maybe other moderators can help ?
Oh well…okok. I think my problem is that I dont understand the card itself. I think it works correctly. thats the most important for the moment.
Thanks for U ans.
Meaning what exactly? How far did you get in importing the dll?
I mean I get this message when I try to install my program:
Consultez la fin de ce message pour plus de détails sur l’appel du débogage
juste-à-temps (JIT) à la place de cette boîte de dialogue.
************** Texte de l’exception **************
System.DllNotFoundException: Impossible de charger la DLL ‘k8d.dll’: Le module spécifié est introuvable. (Exception de HRESULT : 0x8007007E)
à K8000.Form1.Start_K8000()
à K8000.Form1.Form1_Load(Object sender, EventArgs e)
à System.Windows.Forms.Form.OnLoad(EventArgs e)
à System.Windows.Forms.Form.OnCreateControl()
à System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
à System.Windows.Forms.Control.CreateControl()
à System.Windows.Forms.Control.WmShowWindow(Message& m)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.ScrollableControl.WndProc(Message& m)
à System.Windows.Forms.ContainerControl.WndProc(Message& m)
à System.Windows.Forms.Form.WmShowWindow(Message& m)
à System.Windows.Forms.Form.WndProc(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
mscorlib
Version de l’assembly : 2.0.0.0
Version Win32 : 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase : file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
K8000
Version de l’assembly : 1.0.3342.31068
Version Win32 : 1.0.3342.31068
CodeBase : file:///C:/Documents%20and%20Settings/JFK/Local%20Settings/Apps/2.0/K8GGOB91.9PO/1LKWNT6X.KGB/k800…tion_c3f1cfb1665384ac_0001.0000_84f91ee7a19f86f4/K8000.exe
CodeBase : file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase : file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase : file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualBasic
Version de l’assembly : 8.0.0.0
Version Win32 : 8.0.50727.1433 (REDBITS.050727-1400)
CodeBase : file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
mscorlib.resources
System.Windows.Forms.resources
CodeBase : file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Débogage JIT **************
Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette
application ou cet ordinateur (machine.config) doit avoir la valeur
jitDebugging définie dans la section system.windows.forms.
L’application doit également être compilée avec le débogage
activé.
Par exemple :
Lorsque le débogage juste-à-temps est activé, les exceptions non gérées
seront envoyées au débogueur JIT inscrit sur l’ordinateur
plutôt que d’être gérées par cette boîte de dialogue.
woops ok…it ok now…I made a mistake. I forgot to place the dll in c/windows/system32.
my prog run :slight_smile:
thank you…(or thank me)
Yes that was what the compiler was telling you
Have fun;)
