Can I use my K7200 like a charger ?
Yes.
Carefull: Only for NiCd/NiMH or Lead Acid batteries. It will never stop charging, you will have to disconnect the batteries after charging.
Thanks, but I have a little problem with the limitation of current , when I put it in zero I still have 1,70A !!!
Check your assembly, espacially the shunt resistor wires, and redo the calibration of the current limit circuit.
OK, I will check the resistors R37, R38, R39 and R40
I checked the shunt resistor wires and I found effectively some problems with quality of the solder, as you can find in the pic
The reparation phase
Fixed the problem
Then no problem with the current limitation,
but after checking the system with the oscilloscope the ondulation is between 800 to1200mV
, need some helps please
any suggestion is welcome!!!
This is quite normal. When in current limit mode it continuously adjusts the voltage in order to maintain a stable current.
Thanks ,
My system works perfectly
