Hi
I have a Velleman K7200, which is the 0-30 V / 0 - 10 A power supply unit.
This unit works very well but I never got the current display working (the voltage display works fine!)
The 7segment displays just shows 3 dots (. . .) and no values. When I connect the CS input of the display module to the ground, the display shows a stable 0.00.
Any ideas how I could find and solve the problem? I’m not sure if the problem is caused by the display module, or by the K7200 main PCB.
B
