K7103 Sofware and Info
Any one have a the Software for the K7103?
There are some links here but all seem dead or old.
https://www.box.com/s/071af3526c4e5ec4427b
Is there a BOM or schematic for this device?
Thanks.
Here is now the updated link.
And here is the circuit diagram.
Thank you for your links, they are very helpful! I was searching for these diagrams for a long time…
Now, not all software was compatible with Windows, the system had to leave support for DOS applications and the files belonged to them too. They could run like under DOS but without the graphical interface with central graphics and drivers. There is a PIF program but it would require a sweep. Then you can perform a raid data recovery to set up the visualisation later on Windows. DOS applications using only system calls will be shown in a special window. Codes must be entered there to make it work.
