K7103 pc scope
Question I have this pc scope, I have the software for windows but I need the software that runs under DOS.
I assume the file DSO3.ZIP is also sutable for the K7103 and contains the manual referring SCOPE.COM and necesarry files?
As a fanatic velleman fan I thank you very much in advance.
Best regards,
Maurice
Yes, the DSO3.zip contains the setup files for the K7103 DOS software.
Extract the package and run the INSTALL.EXE to create the program folder C:\K7103US.
Then in the program folder run the Dso.bat.
The oscilloscope screenshot images will be saved to the subfolder \data.
Here is the link to download the DSO3.zip: box.com/s/071af3526c4e5ec4427b
The DOS software run under Windows 7 via DosBox emulator ( 32 and 64 bits )
[quote=“superstroker”]Question I have this pc scope, I have the software for windows but I need the software that runs under DOS.
Best regards,
Maurice[/quote]
Just for curiosity, why do you want to run it on DOS?
[quote=“ichbinsnur”]Just for curiosity, why do you want to run it on DOS?[/quote]The specifications for the K7103:
System requirements:
[ul][li]IBM compatible PC using 386 or higher microprocessor[/li]
[li]VGA display card and mouse[/li]
[li]460kb conventional memory available[/li]
[li]works with DOS, Windows 3.11, Win95 and Win98[/li][/ul]
Once something requires “conventional memory”, you instantly know how old it is :slight_smile:
