K7102
Hello!
I have build the metal detector and when I try co calibrate the kit, the led stays on.
I have resolderd and rewinded the coil (120 windings for a-b and 40 windings for c-d), changed the battery, and changed the capacitor (C1), but nothing works. Does anyone know what’s the problem?
Thank you for your help!
(sorry for my bad english)
Can you link to some hi-res and sharp pictures of your assembly (both solder and component side) so that we can take a look?
http://picasaweb.google.com/107847333717546069127/K7102#
I have the same problem.
picasaweb.google.com/JesusM.Palo … 1496759394
I think that I have the solution!
Could it be that you need to remove isolation on the end of the wire?
When I do this, I can turn the light off and detect metal on 1,5cm.
:slight_smile:
Hello, isolation? the tape is concerned, the solution proves ok.
Thanks.
