K6501 problem
Hi !
I’ve recently built this kit and it works perfectly !
I can turn it on / off from my mobile phone (all 3 outputs - I’ve soldered 3 relays).
Now, I’d like to use it to turn on / off the heating when I’m away, but I have only one small problem: If there is a power failure, k6501 will “forget” the output status, resetting all of them to off when power is restored.
I will sure use an UPS system, but in my area, power failures are rare and may last several hours so the UPS is useless.
Is it possible to rewrite the code in order to remember the output status ?
Thanks,
dac
The processor does not feature eeprom memory, so this is not possible.
