My VM140 works perfectly under windows 7 and I am building a Delphi program to automate my aquarium ( 8 lighting timing, 2 T° controler, 1 PH controler with CO2 injection management, 3 water level high & low management, etc…). I feel more comfortable with Delphi than with electronic.
ok, the VM132 (K8067) can be use with a VM140, but VM132 has a slow response time and may be used only for T° control.
The K6001 looks more versatile ( more easy t° ajustment into my required range : 20°c to 35°c, which means more accuracy, only 2 wires sensor input ) and …
…because I would like to try to also use a K6001 connected to a PH electrode which work on the same sensor principle.
The question : may I connect 3 x K6001 to the analog inputs of my VM140 ?
If yes, I have a few more questions.
sorry, I do not kown nothing in electronic
1/ what is the outpout voltage range of the VM132 ?
2/ the in/out connectors are 5 and I have 6 connexions to do
I understand where to connect the sensor ( 2 connexions on the right), but where to connect the + and - 12Vcc input as well as the 2 outputs for my VM140 analog input , and which VM132 output to VM140 GND and which to VM140 AD1 ?
3/ for the VM132 offset RV1 calibration , I need to have 2 connexions to my digital mesuring apparatus : ok, one will be on the common connexion between R2 and R7, but again, what about the second ?
Many Thanks and best regards.
hi, i can’t help you but i’m interresting to know how you add a phmetre in your velleman card and all other tips
(for my aqua)
tks
K6001 is a digital-out sensor and cannot be used with VM140.
Zut, tant pis, je vais donc devoir utiliser un vm132
… mais vraiment aucun moyen de transformer (facilement) la sortie du K6001 pour être utilisable avec l’analog input du VM140 ?
Bonne journée
For Moriss : could you read the french ? if not I wil try to translate the following for you
j’ai trouvé un circuit pas trop compliqué içi : simplecircuitdiagram.com/200 … voltmeter/
cette mesure de sortie convertie en 0v à 10v sera branchée sur une entrée analogique de la carte velleman VM140, ce qui me permet de faire les calculs ci-dessous sur mon ordinateur.
en fait je suis parti des infos suivantes :
mesurer un PH revient à mesurer une faible tension ( : ddp mesuré)
ddp mesuré= a.pH + b.
Le “a” est la pente de l’électrode et devrait être égal par exemple proche de -0,059 V. Pour l’électrode de verre “a” en est peu différent. Cette pente est fonction de la qualité de l’électrode (et de son vieillissement), et l’on considère qu’il ne doit pas s’éloigner de plus de 5%pour considérer la mesure comme acceptable.
Le mieux est donc de calibrer une nouvelle électrode et d’enregistrer son propre “a” neuf. Son usure sera acceptable tant que ce “a” restera dans la fourchette des 5%.
le “a” varie un peu avec la température !
le “b” est un coeff à déterminer pour l’électrode utilisée.
qualibration : ( attention à la température)
on a deux mesures : ddp4 faite à PH4 et ddp7 faite à PH7
On a donc deux équations à deux inconnues :
ddp4 = ( a * PH4) + b où PH4 = 4 et ddp4 est le voltage mesuré
dd7 = ( a * PH7) + b où PH7 = 7 et ddp7 est le voltage mesuré
il est donc facile de calculer a et b
a = (ddp7 - ddp4)/3
b = ddp4/(a4) ou b = ddp7/(a7)
une fois ces valeurs trouvées, convertir une ddpmesurée en PH se fait avec la formule :
PH = (ddpmesuré - b) / acorrigé
attention, le “a” varie un peu en fonction de la température :
par exemple 0,05916 à 25° et 0,05816 à 20°
le facteur de correction à ajouter/retirer de “a” est ci-dessous
Temp°C Correction Factor
40 Plus 0.45
39 Plus 0.42
38 Plus 0.39
37 Plus 0.36
36 Plus 0.33
35 Plus 0.30
34 Plus 0.27
33 Plus 0.24
32 Plus 0.21
31 Plus 0.18
30 Plus 0.15
29 Plus 0.12
28 Plus 0.09
27 Plus 0.06
26 Plus 0.03
25 0.00
24 Minus 0.03
23 Minus 0.06
22 Minus 0.09
21 Minus 0.12
20 Minus 0.15
19 Minus 0.18
18 Minus 0.21
17 Minus 0.24
16 Minus 0.27
15 Minus 0.30
14 Minus 0.33
13 Minus 0.36
12 Minus 0.39
11 Minus 0.42
10 Minus 0.45
super merci beaucoup, je ne savais pas que tu étais français
Petit demande, accepterai tu de ma filer tes sources ?
Apres avoir jouer avec Profilab, je vais voir du coté de Delphi
merci
PS : tu trouveras mon mail dans mon profil
