How do I test the trigger coil on the K5300 strobe light? I get zero ohms between the input and ground and 63 ohms between the output and ground. The lamp will not flash and I do have the proper voltages. Sincerely Dale
Those measurements look OK for the coil.
Maybe the flash tube is damaged or defective.
We assume you are a US resident.
In that case, you can call (817) 284 77 85 for local tech support.
Thanks: I poked around and it started working. I re-soldered some suspicious looking joints. I was stuck on the coil because I just thought zero ohms seemed wrong to me. Thanks Again
