K5200 inductive loads & sequencer
Dear sir,
I’am making a second unit with the K5200.
I have some questions about it.
Can K5200 switch inductive loads ?
How can I connect the MK103 “sound to light” as a sequencer on the K5200 ?
Is it possible to connect the IN(K5200) between R9 and LD1(from MK103), and the GND on the cathode
from LD4 ?
Best regards,
Branco
K5200 can handle slightly inductive loads if it is set to synchronous mode.
Syncronous mode does not allow the hook-up of an external oscillator.
At the input you need to apply a TTL signal.
WARNING: the complete circuit is connected to the AC grid!
If you connect an external circuit, it will also be connected to the AC grid!
The MK103 option has not been tried before.
Once again: be extremely careful when you connect an external circuit to the K5200.
Make sure it cannot be touched when K5200 is plugged in.
