Hi.
I’m currently soldering this audio kit (K4700 speaker protection kit).
I’ve reached step 8. PCB tabs. and one is missing. Found only 9 in the kit but there are 10 PCB holes.
Think that the explanation is in the manual … only one checkbox for MAINS (N-L) 1 checkbox but 2 PCB tabs needed.
Not a big deal since a simple wire could do the job as well but it should be mentionned to complete this kit.
This is my second velleman’s kit and i greatly appreciate the understandable explanations, the tidy PCB and the components in order.
Tried other kits from other brands and some of them were a big mess.
So thanks for this quality.
Oh and one question about the difference between symmetrical and asymmetrical power supply.
symmetrical means 2 transformers in the amplifier and asymmetrical means one ?
I’ve build this kit twice already and no pins were missing…
Symmetrical means output stage is powered with a symmetrical power supply (e.g. +56 and -56 Volts), while asymmetrical means powered by an asymmetrical power supply (in the example: +56 Volts). Asymmetrical power stages mostly have a big output elco.
