K4700 not functioning well?
after a three years of flawless operation my K4700 started to switch off the speakers. It happens shortly after i switch on my stereo set (Quad 34 and Quad 405). Without the K4700 the set works fine. The sound is not cut off directly, but with a crackling noise.
The functional check of the k4700 is OK: yellow light dims, connecting PA (L & R) to V- results in a click of the relays and the red led lights up.
What seems to be remarkable is the way the unit is activated. After about 6 secs the yellow led dims. But the clicking sound in the relays is very low: it is not a clear or strong click.
Can there be something wrong with the circuit? How to check if all is OK?
Thanks in advance.
Eric
Because this is an analog circuit, the problem could be a lot of things
T1,T2,T4,ZD1 the IC LM324,…
Start to check the transformer.
You must understand that it’s not possible for us to say what the problem is w/o checking out the kit.
