Can you help me ?
i have two 4700 kit to connect behind two mono power amplifier to protect my loudspeakers.
Each power supply for power amplifier is +34V 0V ( asymetrical supply) : must i mount 1w R23 to R26 resistors or not ? (in french notice itâs not very clearâŠ)
Each power amplifier is based on CL3 classe D module which have differential output and must not be especially connected with the mass.
Is the infosheet_k4700_mono.pdf the right one and
where do i connect the reference off 4700: on 0 volt of power supply or on
the ground off the input Cinch off my power amplifier?
Will it be a solution by mounting the 1W resistors?I m afraid it provoke dammages to my classe d amplifier (CL3 module) .
May be those modules CL3 are not compatibles with K4700 ?
We are sorry, but we do not have any experience with this kind of amp. We suspect it is an asymetrical supplied bridged amp, which is not compatible with this kit (DC protection part of the kit, turn-on delay will work). In this case, D7 and D8 should not be mounted. Apparantly, the manufacturer of this amp is out of businessâŠ
