K4700, capable of switching high current (DC)
Will the relays supplied with this kit properly work when high DC current is present?
In my case the rail voltage of the amp is ±80VDC, direct coupled design, in case of output device failure the full supply voltage will be present at the speaker outputs - e.g. at the relay contacts.
