Is the K4306 a true ‘Volume Unit’ type meter? Are the meter ballistic characteristics actually conforming to the rise and fall times (attack and decay) of a true VU meter (which is a needle analogue device) or is this name just your description of an audio meter?
If I connect it to an audio source will the meter actually show me the peaks which a true VU meter does not?
The LM3916 datasheet shows the module can be used to drive "average OR peak level indicators".
I can’t discover from the datasheet which indication is displayed by your circuit. The VU meter is an averaging type and digital meters are usually peak reading. hence my confusion when a digital LED bar meter is described as ‘VU’.
