K4040 Voltages.
Hi guys.
This is my first time post on this forum so please bear with me if I appear a little slow…
I have the K4040 power amplifier. I built it about ten years ago and it has been the best amp I have ever owned. I noticed lately that it hasn’t been sounding so good and I have to be honest to say that I probably haven’t set the bias voltages in two years…
So, I got my DMM out and set them – perfect! I prefer to set them this way so I am sure I have the correct value. While I had the covers removed I thought I’d give it the once over and measured the PSU voltages, both primary and secondary AC, and the DC values. I am concerned that the secondary are not what I expected and the high voltage DC voltages are way out.
The mains input is set at 245VAC, the actual mains input: 241VAC.
Power Transformer Values.
Heater voltages: 6.8V although they have been as high as 7.3V.
300V (red taps): 293.3V.
50V (yellow taps): 47.3V.
HVDC.
J1&J3 should read 415VDC – actual value: 395VDC.
As for the other DC high voltages they can differ by as much as –40 volts, 365VDC for example reads 325VDC. The other DC test points vary greatly, but all are way too low.
I am wondering if a couple of the power caps are on their last legs, although physically all looks good.
I would very much appreciate some input on what is the probable cause of the voltage differences.
Many thanks,
Charlotte.
