02/26/2010
I purchased one of your K4020 stereo Mosfet amplifier kits from Hobby Tron.
The serial number is #0903.
Although I once studied and then taught electronics up to about 35 years ago, I left the field and pursued another career. I apologize whole-heartedly if I have made mistakes regarding the following.
I have a number of questions.
The schematic on page H4020-ED2-55 shows T10 and T11, both of which are IRFP9140 P-channel Mosfet’s connected by what appears to be with the Source and Drain reversed. The Drain of each is connected to R78 and R79 (0.22 ohm) respectively, both of which are then connected to the +40 volt DC supply.
With Op Amps A1 and A2 driving the Mosfet’s Gate, Drain to Source and feedback for A1 and A2 being the voltage drop across each 0.22 ohm to Drain, I just cannot seem to see how this could possibly work.
But then after carefully studying some of the traces on the circuit board (P4020’2), the drains of all the Mosfets T10 & T11 (IRFP9140 P-channel) and T12 & T13 (IRFP140 N-channel) appear to be connected together. If each of the Op Amps drives the connected Mosfet Gate with each respective Mosfet Source connected to it’s respective supply voltage via the source resistors (0.22 ohm), the circuit seems to me it should then work.
Confused by what I found, I downloaded what appears to be some revision (manual_k4020.pdf), which confuses me even more.
Mosfets T10 & T11 are depicted the same as the printed manual that came with the kit.
The circuit board part number in the PDF is P4020A’3. The circuit board that came with the kit is P4020A’2.
The schematic’s have several differences though.
The kit has a 3.3K ohm resistor for R52 and no high frequency limiting capacitor across R59 a 39K ohm resistor on the negative feedback side of IC7 (TL061 Op Amp). This gives IC7 an apparent gain of 11.8 (Av = 11.8).
The PDF drawing shows a 33K ohm resistor for R59 and a high frequency limiting capacitor of 33pF across R59. IC7 in the PDF circuit has an apparent gain of about 1.18 (Av = 1.18).
With a gain of 1.18 (almost unity, no gain at all) and with an input sensitivity of 1 VRMS, resistors R53 & R54 (both 180 ohm) feeding the step-down series voltage regulator transistors T5 & T7 for IC7, will only see a maximum voltage swing of 1 Volt peak to peak to drive Mosfet Op Amp drivers A1 through A4 with.
This seems to me it will yield less than 10 Watts maximum into an 8 ohm speaker load, so something does not seem right.
C8 was increased to 330pF from 1nF originally which will roll off high frequency response of the amplifier much sooner. I don’t see a problem with this, but perhaps I am missing something in my understanding how this change works somehow in conjunction with changing R59 from 3.3K ohm to 33K ohm.
I found another change involving the protection circuit, primarily ZD5. This Zener is labeled and used as a 4.3 Volt Zener in conjunction with the ±18 VDC supply being OK (+V1 to –V1) applied to the base of Darlington T9, but then ZD5 is shown used again labeled as a 43 Volt Zener in series with ZD7, another 43 Volt Zener in conjunction with the ±50 VDC supply being OK (+V3 to –V3) applied to the base of T3.
In either case, if ZD5 is 43 Volts in the (+V1 to –V1) supply OK or if ZD5 is 4.3 Volts in the (+V3 to –V3) supply OK circuits, neither will not work unless I am really missing something here too.
So here are a few more questions.
Is there a problem with my circuit board?
If there is a problem with my circuit board what needs to be done to correct it?
Are there perhaps problems with both of the schematics?
If so, can you provide me one that is correct?
Also, is there an explanation of how this amplifier works? If the schematics are correct, I have no idea and I will probably do something incorrectly, rendering damage when I build it.
Please Help.
Sincerely,
Richard Borkowski
837 Lindley Road
Bronson, Michigan 49028
E-mail: Rborkowski@vbs.net
