Hi!
I recently bought two Velleman K4005B amplifier modules (kit). After components assemby, i’ve tested them and everything seemed to be fine.
Each of them is configured for bridge operation. The problem is when i use them simultaneously (left and right signal cable attached to cd player), a terrible hum (50 Hz) appears. The power supply (500VA, 80.000 uF) is intended to be in common use of amplifiers.
Hum does not disappear until i disconnect one amplifier module from player, otherwise everything work great (mono application). I’ve already tried using other sound source.
Can anybody advise me what should i do?
