Thanx a lot for former advice with the volume pot! But I have an another issue that I need to help with…
Because of limited possibilities of our reseller, I can not order the optional component used as sensor for thermal protection and I have to replace it with some OEM part…
But I really do not know WHAT type of component it is? I could not find any closer information in the manual. The only thing I guess - it should change its resistance at a given temperature sharply to zero, and to tell you the truth, I absolutely have no idea about it… Thermistor is much more linear… Some bimetallic switch?
Thank you again in advance for any information!
hase
