I have a couple of questions about attaching the heatsink on the K4003. I am quite the beginner at building thisgs like this, so forgive me if the answers are obvious.
The manual says: The inulation (covered on both sides with some optional heat-conductive paste[…]) mica must be inserted between the IC and the heatsink. My questions about this are:
- The supplied mica in my kit seems not to fit in the intended area - it seems too big. Here’s a picture of what was in my kit - I am holding the mica to the heatsink. As you can see, the screw holes are too narrow to fit the mica between. How is it intended to be oriented?
- How optional is the paste? What are the advantages/disadvantages of using it in normal use? I am intending the amp to be in operation for hours at a time.
Thanks!
