K4003 Bridging?
I’m planning to build a 4.1 computer speaker set based on 3x K4003 (2x15W amp) kits. Would it be possible to bridge one kit for a bolder .1? (The alternative is a DVC sub, which limits my selection somewhat…)
The applied IC is not suited for bridging.
OK, fair enough. Maybe I’ll look at one of the larger amps instead. Underpowering the discrete 200W would probably do the trick, if not a bit overkill.
