My Problem is the outputsignal of may K4000. You can hear the highs rightly good, but there is no power on the bass. when you turn lauder, the bass crashes totaly down.
Here is the Voltage-Check
without any Velves - Speakers on 8ohm output - Input open
6,3 Terminal: left = 6,15VAC right = 6,15VAC
Fuseholder F2 and F3 : 407VDC
with Valve 12AU7 at V6 and ECC83S on V5 left and right:
left right
+V1 403VDC +V1 403VDC
+V3 356VDC +V3 352VDC
-V -45VDC -V -44VDC
point 3 on soket V1 trough V4
left = 403VDC right = 403VDC
with every valve:
TP1 through TP4…left and right 0,4VDC
left right
+V1 389VDC +V1 389VDC
+V3 343VDC +V3 340VDC
-V -50VDC -V -44VDC
6,3 Terminal : 5,98VAC left and right
Terminal for output-Transformator:
left
violett, green, black, black, brown, orange = 388VDC on ground each
right
violett, grenn, black, black, brown, orange = 386VDC on ground each
without E34L:
left
Violett, green, black, black, brown, orange = 403VDC on ground each
right
violett, green, black, black, brown, orange = 403VDC on ground each
I hope you can help me now.
Fritz
