K3504 - Extend the alarm time
first of all, sorry for this english, it’s not my language.
I want to buy a K3504 kit for car alarm but I would like to change a parameter. Being new, I really need your help! :slight_smile:
I would like to extend the alarm time that is announced to 60 secodes. I wish it was at least 5 minutes.
But I do not know if I have to change a transistor or Flip Flop for example.
Can you help me? :slight_smile:
Thank you so much :slight_smile:
You can change C11 to 220uF
this is according to our calculations this is not tested.
Side note: legally an alarm should only go off for max 60 seconds.
VEL337
thank you for your reply :slight_smile:
Other small things. Is it possible to put a drive in place of C11?
Is it possible to connect it with a 951- ULTRASOUND DETECTOR and an ELECTRONIC SHOCK CONTACT SENSOR DETECTOR VIBRATION?
A bit like a K3511 which unfortunately no longer exists.
Only a capacitor can be connected for C11
You can use any detector if it introduces a voltage dip on the battery
example activate a 20W or higher bulb
Ok thank you :slight_smile:
What is the voltage of C11? :slight_smile:
C11, 25V or higher please
