Hi, i nedd to finish this project at monday, but the circuit barking all the time and in the loudspeaker i listen a good barking sound but is not clear, it have oscilations in background, all the components are good soldered.
Thanks for support…
Most likely an assembly problem.
If you can provide links to HI-RES and SHARP pictures of both solder- and component side of your assembly, we can take a look.
