I’ve assembled a k2636. Manual is labeled H2636IP-2004-ED1 (rev. 3). Checked components, diode orientation, solder connections etc. Wired per manual page 8 (110 VAC, 60 Hz).
- when I apply power, the power LED comes on (load present or not).
- Both fuses are OK
- 110 VAC appears across load terminals (no load connected), but voltage does not change with any combination of potentiometer positions.
- When I add a load (tried 60 w incandescent light bulb), voltage across load terminals goes to 0, light bulb does not light at any combination of potentiometer positions.
- VDC across potentiometer does change with potentiometer position (both potentiometers).
Any thoughts on trouble shooting?
I’m very experienced, assembled quite a few kits.
Thanks,
MLV
