K2634
hello, I just want to make sure about something in this kit.
from what I understood, all the outputs should be on on the same power supply! (i.e. All triacs must be connected to the same Voltage).
what I mean, you cant control two outputs one on 24AC and the other on 240AC by disconnecting the VAC and just intercepting the connection between the supply and the device.
I know that this kit does not switch DC but is there any add on or modification that makes it work? I welcome any ideas
Regards and thanks in advance
I’m afraid I don’t quite understand the first part of your question.
As for switching DC, you need either a relay board (e.g. K2633 or a transistor/mosfet board, which is not available from our range. There is no way to modify the K2634, you simply need something completely different).
sorry if I was not clear enough. suppose you have two devices, one operates on 24VAC, and the other on 240VAC. Can you control both of them using one K2634 kit?
regards
Theoretically, this would be possible if they both supplies have a common, however, 24VAC circuits usually require galvanic separation for safety, so we’d strongly advise not to mix 240VAC and 24VAC circuits.
