Hello ,
I would like to know the loads that K2634 is certified to drive. In my case there will be 3 low power single phase ac motors, imagine motors like the ones used in
small drilling machines, hairdryers etc. Is this board ready for ac motors at all?
Thank you
Alex
Thank you for your answer. But if I am correct there is no reference to the certified loads in the manual.
A moteor is a lot different (conductive) than a light bulb. It usually requires a small passive filter around the triac, which I dont see on K2634. Also, from a fast look in the manual, I can’t tell what optotriacs are used, which means, I don’t know if they feature zero-cross detection. What am I missing?
Alex
You might want to look at the K2636 (link below)
http://www.vellemanusa.com/products/view/?id=350505
Note: This kit requires that the carbon motor uses brushes.
