I build the K2633 4xrelay card and attached it to the K8055.
When i send to my digital output the LED on the K2633 goes on, but my relay’s won’t switch.
I measure a voltage of only 0.01 V on the base of the relay.
relay: SRU-06VDC-SD-C
power: 9VDC
The board is assembled exactly according to the instructions.
I did not use my USB as power.
My post changed a bit in the editor. I meant to make a sort of table:
K8055…|… K2633
(to USB)…|…( powered by 9vdc on VDC input)
GND ------connect------ GND
CLAMP ----connect----- +VDC
DO1 ------connect------ 1
etc.
Which is what you say.
(So i did that wrong before)
Now I did that for every IN: the LED goes on, but the relay’s is not closing.
Then: Voltage at the base of the relay becomes: approx 0.28 V
I replaced the transistor, but the behaviour remained the same.
Because I need this solved fast, I replaced my relay2(the not switching one) with relay1 (working OK).
Now:
Relay1 is switching in the place where relay2 “no switch” was.
Relay2 is not switching in the place where relay1 “yes switch” was.
I think the problem would be solved, if I could get my hands on a relay that is behaving just like the other 3 ones.
So far I found no datasheet on this relay. So I am bound to you.
I don’t mind paying the cost of a relay. I also have no problem sending the relay to you for checkups.
As you’ve stated that the relay worked correctly when you removed it, I had to assume that the relay was OK.
In order to protect your privacy, do not supply an address here. Use the support form instead. Mention the problem you experience, so we can mail you a spare relay.
I ordered and received two these relay boards and initially had the same problem. What I found was that you had to increase the voltage in to 12 VDC. Relays work great when I did this.
Are there any elelctronic relays that will replace the relays on this board?
