K2625 ploblem with range calibration
good evening
I buy your kit K2625 and I do everything well, I’m sure, I’ve checked it many times
I want to use it with an engine 1 cylinder 4 T so I must calibrate it at 6.000 rpm
Before calibration it display right “00”
I calibrate with a 50 Hz 13 Volt transformer but the range displaied was 10-33 max (not 01 - 99 as in the manual)
So reading in this forum I’ve found to change the RV2 trim from 50 Kohm to 220 Kohm and the range change from 10 to 99 but not stable: when I put a value it change continuosly, example: if a try 60, it change continuosly from 53 to 62 to 56 to 60 or other values
I suppose that you haven’t check this kit for all the values in the manual’s table 1.
Please help me because the kit is not very cheap and I need it very urgently
thanks & Bye Michele
If you have an oscilloscope, check signal at collector of T1.
If necessary, reduce value of C12.
[quote=“VEL417”]If you have an oscilloscope, check signal at collector of T1.
If necessary, reduce value of C12.[/quote]
unfortunately i haven’t an oscilloscope and I can’t check signal of T1; but I have tried to reduce C12 to 82n, 68n, 56n, 47n and 10n but don’t happens nothing: around 6000 rpm it continue to be unstable, it change continuosly value.
Note that this don’t happens if I try calibrate it around 4000 rpm or 7000 rpm in these cases it is stable
Waiting from you Thanks & bye
Sorry, at this time we do not know what might be at cause.
We can offer inspection/repair if you return your kit to:
Velleman Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
Make sure to include a copy of this conversation.
[quote=“VEL417”]Sorry, at this time we do not know what might be at cause.
Legen Heirweg 33
9890 Gavere
Belgium
Make sure to include a copy of this conversation.[/quote]
Is very difficult and expensive for me send you the kit from Italy to Belgium, but I’m sure that you can check one similar kit and find the problem; I’ sure that my kit is mounted correctly, also my reseller tell that it is Ok and that the problem is on the project.
I think that is a very good thing that Velleman make everithing for the satisfaction of his clients, even where is problems that can be resolved for the futures kits: it should be a gold medal for you.
best regards
Michele
Michele[/quote]
I’ve found the problem:
your project have two problems and one of these is very big
the circuit can’t count correctly the rpm and it can’t display from 01 to 99 because…
if you’re interested to the resolutions, tell me
if you’re interested to the resolutions, tell me[/quote]
hello my inglis is not so good , but i have the same problem ,
y read that you fix the problem for calibration
do you want to tell me what you do …thank you
