Just bought the kit and when I input 12v from my PC’s power supply, I don’t get any reading off the displays. There is voltage to the regulator, 8v, but when I test the RV1, there’s no voltage.
Any ideas?
EDIT: I also burned my finger touching the displays chips…
It’s always difficult in the begin.
Trought mail is always difficult to give a diagnose or solution, maybe an IC is damaged because of the wrong mounted cable ? You can always return the kit if you want via your dealer.
Make sure kit functions OK before moving on to final mounting in a car.
Replace IC’s, they are quite cheap. Check all solderings and PCB tracks.
Perform calibration as described in manual.
Connection is also described in manual. Unit needs positive 12V pulses (e.g. from primary side of ignition coil). Seek local help if you lack experience.
