This module is now made in mark2 form,different relays,board modified to suit and designated 2599"2.Did no-one notice that,because the new relays are taller than the rotary switch,you can no longer fix it to the back of a panel or the dashboard and you certainly have no chance of seeing the led? Solutions please,without drilling 4 extra holes in my dashboard. [/code]
Just mount the relays on the “solder side”. It’s tricky but if you use a wire in each hole bent over and “tacked” to the pad it works. I too, wondered why they thought changing the physical specifications of a design needed no consideration. Too late now though.
