K2579 to start when power is on
Hello, is there a way for K2579 to be in START mode when you connect it to power rather than being in STOP by default?
I just want to control something through power supply so it would help if the kit was lets say ‘always on’ as long as there is power running through.
Is a bit useless because when power would be removed then, the kit would also go immediately into stop because no power anymore to work. This way this kit turns into an expensive and too much complicated wire …
A better option would be MK188 or VM188 set to single shot mode.
http://www.velleman.eu/products/view/?id=408232
