Is it possible to run this kit in a car than a power supply by changing a component or something?
I have a transformer the emulates a 12v car battery and the kit worked fine but when I connected it to the car though the cigarette lighter the kit did not work.
Then tested is again on the transformer again I found that I had blown it.
Most likely you’ve inverted the polarity, which destroyed the IC.
Theoretically, you can use this kit in a car, however, there are better alternatives, such as the K8015.
[quote=“cdgold3”]Is it possible to run this kit in a car than a power supply by changing a component or something?
I have a transformer the emulates a 12v car battery and the kit worked fine but when I connected it to the car though the e cigarette lighter the kit did not work.
(Now ordered new components to repair it)[/quote]
In my case it was also didn’t work when I tried to connect it to the car through the cigarette lighter.
I bought this kit to get my 12yr old into building circuits… but we are starting with this kit because I need a timer… can I make this kit run on even less DC power… like the mute button of my TV remote… or would I need to try and add a near-infrared emitting diode to run the kit as it is.
I don’t know why, but TV just seems so much better if I mute the commercials… just un-muting is the problem… hulu is 60 seconds… network TV can be like 3 to 5 minutes… and people pay to have as much as 1/3 of every hour of TV, stuff they don’t even want to see… over a year, that can add up to a few hundred dollars they are being robbed of.
Just adding software to run the TVs own mute as a timer would be the ideal way to go, but for some reason I really don’t think that’s going to happen… every TV I’ve owned has need the time set, but for some reason it’s too much for a TV to tell me the time of day.
I have used a K2579 very successfully with small 9v dry batteries, but now need to extend the operating time. I want to use a 12v SLA battery, but when I connected it the Transistor blew in a quite spectacular way. I have replaced the Transistor but it still doesn’t work so presumably I have blown several bits at the same time…no matter I have bought a few more K2579s.
The real question is, can I use a 12v SLA battery, or is the circuitry very sensitive to over voltage, as the SLA is going to be a little bit over, say 12.5-13.5v. If that’s the case, can I step down the voltage to about 10v by putting a resistor in series with the board, or is that too simple?
(I know there was a comment that this can happen if the supply is connected wrongly, but I’m sure I had the terminals the right way round.)
Hope there is a solution, just don’t want to find out by trial and error by just keeping on blowing them up!
