A note for Quality control.
I had to file down the edges of the pcb to enable it to fit the edge connector. Also it is obvious that the board was not designed for the 1 microfarad capacitors supplied. The hole centres are 13 mm, but the 63v working capacitors are over 15 mm long, so they had to be installed a few mm above the pcb.
