K2543 six volt transistor ignition
Hi, I want to build two SIX volt modules for a two cyclinder car. The resistors required to modify the module to six volt are all ONE watt. Maplins ( My supplier) says you cannot get 1 watt resistors only 0.6 watt… My question is, is it OK to use 0.6 watt resistors? Many thanks Tony
No, they must be 1W or more.
Maybe Maplin does not carry them, but they do exist…
