K2543 OK for 3 cylinder engine?
Don’t see why it shouldn’t be, but I note the specs mention “practicality test on 2-4-6-8 cylinder engines” so I thought I’d better check, since I want to use it on a 3-cyl Daihatsu Charade, currently fitted with points ignition.
Yes, as long as the engine is equipped with a classic ignition system with breakers, ignition coil and negative ground, the kit can be used.
OK, thanks
