Hello, is it possible to use the K2543 on a Moto Guzzi 850 of 1980 vintage?
It is a V twin with a separate set of points and a coil for each cylinder; the K2543 instructions only show one set of points and one coil.
Here is the wiring diagram for the motorcycle…thanks.
If it will work at all you would need (2) K2543s one for each set of points / coil.
Remember these units need 12 volts and each unit can pull up to 4amps
Thanks for the reply. Using 2 sets will therefore pull 8A; my alternator produces 20A so I guess its up to the job.
My main worry is the heat generated by these kits having read a few posts in the forum.
Remember this is just a guess on my part if this will work on your bike.
20 amps from your alternator may not be enough.
Remember it needs to keep the battery charged run the lights and keep the engine running.
You maybe asking to much from the alternator.
