K2543 doesn't work on Triumph TR4
Installed K2543 electronic ignition according to instructions: no spark at all. Connected connection 1 with the ignition coil’s +. Could that be the problem? Because as I switch off the contact, there seems to be a glimpse of starting.
Thanks, Charley
Hi Philippi,
I got the same problem.
I solved by connecting a resistor 8 Ohm/5 watt in between the coil and connection 3.
I have nice sparcs now!!
It seems to me, the coil consumes to much amps and the darlington will not reset anymore.
Grtzz
Damax,
Thanks, try it immediately tomorrow. Keep you posted about the results.
Charley
