When I try to reflesh the module with the firmware, there are the following errors:
Arduino: 1.8.8 (Windows 7), TD: 1.45, Board: “ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None”
CLOCK_FIRMWARE_1.0:123:28: error: ‘NeoEsp32RmtWS2813_V3Method’ was not declared in this scope
NeoPixelBus<NeoGrbFeature, NeoEsp32RmtWS2813_V3Method> strip(PixelCount, PixelPin);
CLOCK_FIRMWARE_1.0:123:54: error: template argument 2 is invalid
CLOCK_FIRMWARE_1.0:123:82: error: expression list treated as compound expression in initializer [-fpermissive]
D:\Projekte ESP32\K2400-BrightDot-Clock\CLOCK_FIRMWARE_1.0\CLOCK_FIRMWARE_1.0.ino: In function ‘void setup()’:
CLOCK_FIRMWARE_1.0:148:9: error: request for member ‘Begin’ in ‘strip’, which is of non-class type ‘int’
strip.Begin();
CLOCK_FIRMWARE_1.0:149:9: error: request for member ‘Show’ in ‘strip’, which is of non-class type ‘int’
strip.Show();
D:\Projekte ESP32\K2400-BrightDot-Clock\CLOCK_FIRMWARE_1.0\CLOCK_FIRMWARE_1.0.ino: In function ‘void codeForLEDtask(void*)’:
CLOCK_FIRMWARE_1.0:193:17: error: request for member ‘SetPixelColor’ in ‘strip’, which is of non-class type ‘int’
strip.SetPixelColor(i, RgbColor (0,0,255));
CLOCK_FIRMWARE_1.0:194:17: error: request for member ‘Show’ in ‘strip’, which is of non-class type ‘int’
strip.Show();
CLOCK_FIRMWARE_1.0:199:17: error: request for member ‘SetPixelColor’ in ‘strip’, which is of non-class type ‘int’
strip.SetPixelColor(i, RgbColor (0,0,0));
CLOCK_FIRMWARE_1.0:200:17: error: request for member ‘Show’ in ‘strip’, which is of non-class type ‘int’
strip.Show();
CLOCK_FIRMWARE_1.0:208:17: error: request for member ‘SetPixelColor’ in ‘strip’, which is of non-class type ‘int’
strip.SetPixelColor(i, RgbColor (0,255,0));
CLOCK_FIRMWARE_1.0:209:17: error: request for member ‘Show’ in ‘strip’, which is of non-class type ‘int’
strip.Show();
CLOCK_FIRMWARE_1.0:214:17: error: request for member ‘SetPixelColor’ in ‘strip’, which is of non-class type ‘int’
CLOCK_FIRMWARE_1.0:215:17: error: request for member ‘Show’ in ‘strip’, which is of non-class type ‘int’
strip.Show();
CLOCK_FIRMWARE_1.0:334:17: error: request for member ‘Show’ in ‘strip’, which is of non-class type ‘int’
strip.Show();
D:\Projekte ESP32\K2400-BrightDot-Clock\CLOCK_FIRMWARE_1.0\CLOCK_FIRMWARE_1.0.ino: In function ‘void ClearArrays()’:
CLOCK_FIRMWARE_1.0:1633:11: error: request for member ‘SetPixelColor’ in ‘strip’, which is of non-class type ‘int’
strip.SetPixelColor(i, color);
D:\Projekte ESP32\K2400-BrightDot-Clock\CLOCK_FIRMWARE_1.0\CLOCK_FIRMWARE_1.0.ino: In function ‘void BlendArrays()’:
CLOCK_FIRMWARE_1.0:1666:11: error: request for member ‘SetPixelColor’ in ‘strip’, which is of non-class type ‘int’
Mehrere Bibliotheken wurden für “WiFi.h” gefunden
Benutzt: C:\Program Files (x86)\Arduino\hardware\espressif\esp32\libraries\WiFi
Nicht benutzt: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Dieser Bericht wäre detaillierter, wenn die Option
“Ausführliche Ausgabe während der Kompilierung”
in Datei -> Voreinstellungen aktiviert wäre.
What goes wrong?
Thank you for your help
Helmut
